http read
hi
 i want to read run time http link which gennerated on server.so please help me for this ....
(3,853 Views)
(3,843 Views)
If you don't have the Internet VIs installed, you can also use Datasocket Read by adding [text] to the URL like this:
___________________
Try to take over the world!
(3,829 Views)
I tried this but i got only header part not actual data part for example:Name:  <br/>User ID:, now i want actual data.
(3,806 Views)
The code uses the HTTP protocol to get the data at the URL. If the data you want is not at that URL, then you need to find out where it is.
___________________
(3,799 Views)
