hue component value from HSI image
Hi, Can any one help me to find hue component value from HSI image.
Thank youy
Message 1 of 8
(3,746 Views)
Use "IMAQExtractColorPlanes.vi"
Christian
Message 2 of 8
(3,737 Views)
Thax.
But i am looking for hue value not plane.
Message 3 of 8
(3,729 Views)
Did you have a look at this function?
I assume you didn't. But you should, and you should read the help too.
Christian
Message 4 of 8
(3,727 Views)
Hi.
 I am sorry. I did. I did many projects on NI vision assistant.
i shud get hue value of Red apple range 0 - 20 after selecting ROI.
I extracted HSI plane then applied histigram. But results are not matching.
As per my alogortithm Plane is different from Hue value.
Thank you
Message 5 of 8
(3,717 Views)
Hi.
Thank you
Message 6 of 8
(3,717 Views)
I don't really get what you want, sorry.
Why don't you use the Histrogram directly at the color image with the HSL Model?
Christian
Message 7 of 8
(3,711 Views)
Here i have attached my code. I did up to ROI perfectly.
Then i converted to HSI image.
From HSI i want hue value. And it should be 0-20 for red apple.
and 25 to 50 for yellow apple.
Give me any hits.
Message 8 of 8
(3,707 Views)
