humidity
has anyone out there used labview to measure\control relative humidity? i
would just like to hear your thoughts.
good day,
jason
(6,197 Views)
Hallo, shawn,
Du meintest am 21.06.99 zum Thema humidity:
> humidity?
First you should choose a sensor. The VI is as simple as any other vi
which gets data from a sensor.
Viele Gruesse!
Helmut
(6,197 Views)
> good day,
> jason
The comments about humidity measurements being no different an animal than
measurements using some other sort of transducer are right on the money, so
the problem probably does boil down to identifying a good transducer for the
task.
You can see one example of a humidity sensor in action on NI's SCXI Weather
Station pages: http://weather.ni.com/weather.htm
The system specifications given there do not identify the manufacturer or
model of humidity sensor used, but the sensor's input/output characteristics
are provided (0.002 V to 1.0 V output, corresponding to 0.2% to 100%
humidity; I d
oubt we have a need to measure humidity below 0.2% too
frequently down here in Austin!). I imagine you could get something pretty
similar from Omega Engineering or elsewhere.
Best Regards,
John Lum
(6,197 Views)
