i am trying to design a data acquisition system using labview 8.2 software.during continous sampling in DAX mx analog edge trigger i got the error code 200077.i dont know how to solve it. i could not do the file wriing for analog data aquisition
 i am trying for analog data acquisition system in NI6229 card using labview 8.2. i got error 200077 while using DAQmx analog edge trigger.vi. and i dont know how to acquire and store data. can u please give me some suggestion.
my mail id.muthuselvi.krishnan@gmail.com
(3,239 Views)
Are you using an example VI? I was not able to find this VI in examples. Can you post it here?
May be you can try using the example VI in "<LabVIEW 8.2>\examples\DAQmx\Analog In\Measure Voltage.llb\Acq&Graph Voltage-Int Clk-Analog Start w Hyst.vi"
Also next time you start a new thread, try to have a smaller subject line  Smiley Happy
Message Edited by kikiduu on 07-07-2009 01:41 AM
"A VI inside a Class is worth hundreds in the bush"
യവന്‍ പുലിയാണു കേട്ടാ!!!
(3,232 Views)
From the specification, 6229 supports only digital trigger. Looks like you are getting the error because of this.
Message Edited by kikiduu on 07-07-2009 07:33 AM
(3,213 Views)
