i have extensive gui application ,i am using events ,but i am caught,i want to konw abt events ,there pros and cons,time out ,how to program in time out
It is unclear as to exactly what you are asking. The event structure is very handy for monitoring front panel activity and performing tasks accordingly. The default event in the event structure is the timeout. In order to set the timeout you just wire the amount of time before timeout (in ms) to the timeout terminal of the structure. You may have tasks that you want to perform at timeout or you may just have an empty case. I strongly suggest using a timeout and putting the case structure in a while loop in order to keep monitoring the events until the loop exit condition has been met.
