You should make the "append to file?" of the "write to the spreadsheet
file.vi" true.The default setting is false.Then the new data will writes
over the previous data.
matrix wrote in message
news:506500000008000000491B0000-986697009000@quiq.com...
> i am writing to a file, and then later in my program, i open it up
> into a table, however, if i restart the program, it writes over the
> previous data, how can i add to the original data.
[Attachment example.vi, see below]
