i can't control vi via the web
Dear all,
i am now doing my final year project and i got some trouble. My
project is write a Automatic testing & Adjustment System. And now I
try to view and control a front panel of a vi remote via IE on a
second PC.
I have selected in the Tools->Options->Web Server:Browser Access:
Allow Viewing and Controlling.
I view the front panel on my remote (second PC) machine but, I cannot
control it.
Can anyone tell me how to control the front panel to control the
instrument on the server.
p.s. the server in my university haven't got a internet toolkit, can i
still control it?
Server: Test.vi
Labview 6.1(FDS)
Client: Only Internet Explorer/netscape with TCP/IP
NOT installed LabVIEW environment
(3,069 Views)
Did you try enabling the web server from the pull down menu
tools/options/web server? You also need to specify browser access and
visible VI's that you would like to allow remote access. Finally you
right click on the panel embedded in the browser to gain control of
the remote panel.
Hope this helps.
(3,069 Views)
"p.s. the server in my university haven't got a internet toolkit, can
i still control it?
Yes. In general there are two ways to control VIs over the web. The
first is by remote panel. It does not require any toolkits. You have
to make sure the web server is enabled, and that your access settings
are configured correctly (which it sounds like you have done). You
can then use Tools>>Web Publishing Tool... to help you build a web
page which includes an embedded control for the specified VI. Note
that the client machine will need to have the LV run time engine.
The second method for controlling a VI over the web is to use CGI with
the Internet Toolkit. The advantage of this method is that you don't
need the LV run time engine on the client. The disadvantage
is that
it is much more complex, and doesn't provide the client with a true
front panel image of the VI (you can fake this, but it isn't trivial).
Plus, you need to have a copy of the Internet Toolkit on your server.
As the other post mentioned, if you are still having trouble with
using remote panel, make sure the client right-clicks on the VI to
gain control (LV7.0 allows the user to create web pages which
automatically attempt to gain control of the requested VI).
Hope this helps.
(3,069 Views)
Thanks a lot~~
i can control the VI now after right click on the panel
(3,069 Views)
Thanks a lot~~
i can control the VI now after right click on the panel"
(3,069 Views)
