i can't use epics server with DSC module
Hello,i am new to labview,and i'm using labview2009 with .I tried to add an epics server,and add some variables to the PV list ,but it keeps telling me that i can't because the data type is not supported .I read the help document,found that i am using the right type and i tried all data types but none would work.
So i am really confused and does any one has the same problem?
I am using the chinese version of labview 2009.
(2,686 Views)
You should be able to change the PV name in the Configure EPICS Server I/O Server dialog box by just left clicking on the PV name one time.  The cursor should then appear next to the name, and you can just use the keyboard to edit the name
(2,610 Views)
