i deleted my labview 2010 installation, now i am unable to reinstall it,kindly help please!!!
I did the same with 2009 it worked but after updating to 2010 its didn't, i had to uninstall it for many things was causing a problem, so instead i deleted it and now when i reinstall it,it says that labview is already installed so i cannot install anything on it. kindly help please.
(2,882 Views)
Hi Kacy,
I have not tried the method which I am going to suggest. Please try it on your risk.
Go to Start>>Run
open "regedit"
Delete this item "My Computer>>HKEY_LOCAL_MACHINE>>Software>>National Instrument>>Labview".
It may help you.
Into the pursuit...
Maverick
(2,872 Views)
Kacy,
be extremely careful when editing the registry. It can mess up the complete machine. Make a backup before you touch it.
Cheers
Edgar
(2,863 Views)
I am facing the same problem.
Have you get any solution for this?
(2,844 Views)
This is why there is the uninstall option.  Deleteing the directories does not clean up the rest of the files that are spread all over your computer when programs are installed.
Do a search for MSIBlast, it will help uninstall the programs you deleted.  The new installer is probably looking at the registry settings that normally get removed when you uninstall programsSmiley Happy
(2,830 Views)
