i had problem with my program
i m facing problem with for loop ..
if there were more lines in the text files.. it was running too slowly .. it takes arounf 4-5 mins for reading 25 lines
please frnds.. i needuntitled.JPG to reduce my timings..
Message 1 of 13
(5,606 Views)
Can you attach your VI
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 2 of 13
(5,603 Views)
Hi gowthamggk,
did you try to time your ping command with a simple stopwatch in the cmd shell? Well, it takes some time to ping a target 4 times, when the target is out of reach or far far away.
And now you wonder why it takes 5mins to ping 25 targets?
The ping command allows for several options. Read the help and use them...
Message 3 of 13
(5,597 Views)
i tried it sir.. but i know know y??
Message 4 of 13
(5,587 Views)
i need to speed up my program .
pls help  me any one
Message 5 of 13
(5,586 Views)
Hi gow,
what did you try?
What do you know? What is "y"?
Did you follow our advices?
Message 6 of 13
(5,583 Views)
sorry sir.. i dint get ur idea.. so please brief it.. running out of time.. thats y.. my mind is totally blank 😞
Message 7 of 13
(5,567 Views)
Accepted by topic author gowthamggk
I think your issue is you are using CMD for ping the IP and until unless the popup ping window move out you will not get response.
You can try with attached VI this VI can reduce your processing time.
Thanks and Regards
Himanshu Goyal | LabVIEW Engineer- Power System Automation
Values that steer us ahead: Passion | Innovation | Ambition | Diligence | Teamwork
It Only gets BETTER!!!
Message 8 of 13
(5,559 Views)
one more problem sir..
if i combine the program that u were given with my program , it showing this error
please help me sir..
Message 9 of 13
(5,519 Views)
post a implemented code snapshot or VI for better understanding the issue.
Thanks and Regards
Message 10 of 13
(5,497 Views)
