i'm building an exe with an installer using 6.1 on NT and get a 'class not registered... XML enumerated type choice does not match the wired type' error, but i can build the app without the installer.
The error doesn't actually have to do with XML (Application Builder and XML functions tried to use the same error code 1107). The problem is with a dll not being registered. If you run regsvr32 on C:\Program Files\National Instruments\shared\Installer\MergeMod.dll to register it, Application Builder should then be able to generate installers. This should have been taken care of during the install of LabVIEW. The command line to use is:
c:\winnt\system32\regsvr32.exe "C:\Program Files\National Instruments\shared\Installer\MergeMod.dll"
(2,485 Views)
