i'm reading value from memory addresses one at a time. How can I store my values in an array?
How can I store values in an array as I read them in
from memory?
(2,488 Views)
The bad way: Using a shift register and a build array function node append them to the array.
The good way: wiring the value to the loop boundary and enabling autoindexing. Autoindexing is enabled by default on a For Loop, but needs to be enabled on a While Loop.
Rolf K
Rolf Kalbermatter  My Blog
(2,488 Views)
Thanks Rolfk.
I will give this a try.
Van
(2,488 Views)
