i need NI BIOMEDICAL startup kiT for 2009 version
i m just going to start my work on EMG processing if you can provide me NI BIOMEDICAL STARTUP KIT FOR 2009 VERSION then it helps me alot.
thanks
(2,272 Views)
If you need direct help from NI go Here and select Phone NI they will contact you.
(2,266 Views)
https://decibel.ni.com/content/docs/DOC-12646
Download link is at the bottom.
If it complains about needing the 8.6 run time, it's available here http://joule.ni.com/nidu/cds/view/p/id/1101/lang/en
(2,265 Views)
