i need an urgent help on LabView Coding
Respected Sir,
(2,906 Views)
(2,902 Views)
sir, can you please bulid a VI for me that-
1]From Relay Off to On Position-
 can initiate a timer (When 'x' is ON), as well as turn ON a Numeric Indicator that displays the corresponding input voltage and when ('y' is ON), stops both the timer as well as the indicator and they both hold their values and must have a reset button to reset the values...
2]From Relay On to Off Position-
 Also, now when ('x' and 'y' both are ON), when 'x' goes OFF, the timer should initiate and the indicator should display the corresponding input voltage and when 'y' goes OFF, both the timer and the indicator should stop, and they both hold their values and must reset their values..
Sir, will it be possible to use two use timers and two indicators for this purpose.. sir, please help me out, me in a complete mess...
(2,868 Views)
Keep your messages to the other post.  When someone puts a link pointing to your duplicate post, that means continue all conversation in that thread, otherwise it wastes people's time answering the same questions in multiple messages.
(2,856 Views)
