i use labview 8.0 and i can not run daqmx driver for pcmcia 6062e daq card
i use labview 8.0 on window xp .when i installed a PCMCIA daq card 6062E, i could not run daqmx driver.It is fine to see that the traditional version is working well.When i install daq card sometimes it is working well with traditional driver  but mostly i see error on reading an analog input from PCMCIA daq device.An error called 'base adress' occures .I use last version of driver that is daqmx 8.0.1. and i have installed this correctly but again i could not  see any signal on the test panel for daq-mx driver.I don't know what is the problem.Also when i install PCMCIA daq card Please reply this message.I need your helps.
(2,802 Views)
Hi dipneusti,
I hope you're doing well.  It sounds like you can get the DAQCard 6062E fine with the Traditional NI-DAQ drivers most of the time, but sometimes you will receive this "base address" error.  With the DAQmx driver, it sounds like you are able to run the test panels, but you simply don't see any readings.  Does the device get detected by Windows XP?  You can check this in the Windows Device Manager.  Does the card show up under both NI-DAQmx Devices and Traditional NI-DAQ (Legacy) Devices consistently in the Measurement & Automation Explorer?  This will help us pin-point the issue a bit.  Also, if you do get the test panels to run with the card using the DAQmx driver, I would be interested to see if you can run the following DAQ Diagnostic Utility.  This will test the functionality of the card, and measure internal voltages to make sure th card is still within specification.  Lastly, I would be curious to know if this behavior happens on another laptop as well.  If you have access to another one, see if you can try this as well.  Let us know how this turns out, and we will continue helping you with the issue.  Thanks!
Thaison V
(2,785 Views)
Thanks for your reply.I will try to answer your questions.
I have checked the Device Mananger and I have seen that the device is detected by Windows  XP.  For another question the card shows up under both NI-DAQmx Devices and Traditional NI-DAQ (Legacy) Devices consistently in the Measurement & Automation Explorer.I use a way that I reset the driver for traditional NI-DAQ in MAX,and then i reset the device for NI-DAQmx driver in MAX and again i tried to run the test panel of DAQmx driver but again i saw a wrong signal or noise signal on the test panel i could not see the sinusoidal signal that i connected. i do get the test panels to run with the card using the DAQmx driver,  But could not run the DAQ diagnostic utility.The error was as i specified below.
03.05.2006 09:49:35
Results saved to:  C:\Documents and Settings\serkan\Desktop\Diagnostic Results.txt
Selected Device: Dev1
Device Type: DAQCard-6062E
Serial Number: 107509E
Device Support: (PASS)
NI-DAQmx Version: 8.0 (PASS)
Device Reset: (FAIL)
Error -50002 occurred at an unidentified location
Possible reason(s):
The specified device is not a valid device. The operation could not be completed as specified.
 ------ DIAGNOSTIC UTILITY ABORTED -----
And for your last question i can say that i have used the DAQ card on other laptops.But the results were the same.İ hope to see your reply
Serkan Buhan
Electrical-Elecronics Engineer
Researcher
TUBITAK-BILTEN
(2,775 Views)
Hi Serkan,
If the diagnostic utility is also having trouble with the card and you see the same behavior on multiple PCs, it seems the issue is in the DAQCard hardware itself.  If this is the case, there may be a little bit of troubleshooting left to do, but we may want to have you create a service request with us to to work on this either via email or by phone.  That way if we need to repair the card, we can help you do so quickly.  You can create a service request at ni.com/support by click on the Request Support From An Engineer Link on the left hand side.  Hope to hear from you soon.
Thaison V
(2,767 Views)
