i want ti have multiple of 5 in minutes of the timestamp
how can i get a timestamp with a multiple of 5 in minutes
i want to have in beginning --:00 then --:05 then --:10 then --:15 ...
(3,603 Views)
1 minute is 60 seconds.  So 5 minutes is 300 seconds.  The timestamp is based on the seconds.
Can you give more details of what you are trying to do?  Without some good context, it is hard to give any more advice.
GCentral
(3,565 Views)
Hi there
Here is a code that get the time in multiple of 5 minutes (only the minutes), you can use this as a guide to reach your goal
I hope this works for you as a start of your application,
Regards
(3,515 Views)
http://screencast.com/t/ETdw5pWgdKiZ
Increment property of a timestamp
(3,494 Views)
reformat your dbl indicator to "relative time", and please don't connect "10000" to the wait ms. loop will not respond until then....  Smiley Wink
also Keroba, if you want to pull minutes out of your time stamp....use unbundle by name, slight RG at hand?
(3,452 Views)
