i want to design a bluetooth device in labview......so plz give a block daigram og this
(2,856 Views)
Wow,
you want to design something by letting others do the work?
What kind of homework is this?
(2,853 Views)
You use a Bluetooth device, you don't design one. So please...
(2,852 Views)
Don't ask for readymade solutions, first take some initiative to build your own solution, then if you get stuck at something then ask for help.
you can look in to "NI Example Finder" there are some bluetooth examples available.
With Regards
Miraz
Kudos is better option to thank somebody on this forum
(2,846 Views)
