09-16-2008 03:24 AM
09-16-2008 03:28 AM
09-16-2008 03:41 AM
Look on this easy example: http://www.labviewtutorial.eu/viewtopic.php?f=14&t=328
You will find there two identical VIs (only port numbers are different). One is for PC1 and other for PC2. If you will get prodlems starting VIs, so look on your firewall settings, you have to unlock ports used in these VIs.
