i want to maximize front panel having tab control and tab control should be in centre programatically
i tried this using panel bounds property of front panel
using height width of tab tried to set position of tab
but if the reference 0,0 on front panel is changed the tab goes to out of sight
can any one help me in this regard
i want to use this for having different screens with different resolution
regards
(2,927 Views)
Accepted by topic author mazhar.ali
You can use the Origin property of the panes (VI > Panel > Panes[] > Origin) to move reset the origin of the front panel.
(2,904 Views)
thank you  robweaver
for your time and intrest
this solved my problem
regards
(2,891 Views)
