i want to read the attached file from the second line to the last line befor the first NCOUNT
after i want put it in a array but just the 1.2.3.6.and the 7 column
ex: TIMET 0 1 1 0
after to count how much NCOUNT i have and put the values of every one in long vector or array with one element
(2,540 Views)
Here's a VI I wrote that should help you out. Since you are wanting to place a string in that array, it will need to be an array of all string. Hope this helps.
J.R. Allen
(2,540 Views)
