i want to show up a picture depending on different controls the user selects in labview how do i do it
i want to show up a different pictures depending on different controls the user selects in labview how do i do it
(3,011 Views)
Hey Guys,
sorry i have found a solution my self for the problem i had ,tanhz for your support
vicky
(3,012 Views)
i would like to do the same, so show up a picture by pressing a bouton and closing it after with a button.
Can you tell me how you did it?
Lukas
(2,960 Views)
Hello Lukas,
One simple way to do this is to display images the way you normally would using the Read JPEG File.vi and the Draw Flattened Pixmap.vi. Then for the file path input, have different file paths in each case of a case structure. Then, when you select each case you select the file path and display the corresponding image. There are many different ways to do this in LabVIEW. This is just one way. I hope it helps!
Best Regards,
Chris J
(2,930 Views)
Here's an example of how a .jpg file can be loaded in LabVIEW
Regards
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
(2,922 Views)
