i want to split a .txt file using labview
i hav a problem with splitting a .txt file.. the file has 8 columns from consisting of numbers.. i need to break the file into small files. but i need to keep the rows unaltered. for example
1st file named hs1 -having 100 rows..(but with 8 columns) ..
2nd file named hs2- having 100 rows..(but with 8 columns) etc.
i'm attaching the file below
please send me your valuable suggestions
Kudos always welcome for helpful posts 🙂
(3,947 Views)
Simple mate use a read spreadsheet function use an index array and set of reshape array function.Should do the trick.Try it and let me know if u r still stuck.I will post a vi.
(3,941 Views)
Here's a simple example (8.5.1). Modify as needed.
(3,922 Views)
thanks a lot...it works
(3,907 Views)
