i want to transmit a square pulse through USB port, is it possible?? if not then what is the best way to do that, preferable is with serial then parallel, and its compatibility with vista,XP,and @))7 windows
Intaris wrote:
So if I replace the tunnel with a shift register, my Sock won't be invalidated?
Cool.
Shane.
Not only that.  If you keep adding shift register elements, every sock you've ever lost will be returned!
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 41 of 41
(652 Views)
