i want to use the analog output to generate a sinewave souce as the audio sample source?can i?
Normally the ausio source is " 1khz, odB", NOW i want to realize it by the analong output of PCI-6052.Can i ?And what is the max frequency and amplitude that PCI-6052 Can generate by AO ? Thanks! pls help me to make a vi to attach (i am using lv6.1)?
(2,584 Views)
The output range of PCI-6052E is +/- 10V. The maximum output rate that can be achieved is 333kS/s. You will be able to generate a 1Khz sinewave using LabVIEW. I would recommend you to go thro' the example that are shipped with LabVIEW and look at analog output VIs.
-Arun V
(2,584 Views)
