i want use google map api in VI . i tried so mutch to do it.i used google earth plugin and google static map but i need only google map api .
Hi Everybody,
Thank you for your intersting topic. I have a problem with running the vi.
would you please tell me what is it problem for? P.S:I have used Labview 2020 Running on Windows 7 X32 Best Regards
Message 131 of 134
(1,034 Views)
If you ask about the problem that the map cannot be displayed here. There are two reasons for this. You have not chosen whether to upload a map online or offline. Second, some maps cannot be supported.
Message 132 of 134
(998 Views)
Google Maps:
Google requires you to get an API Key to use Google Maps API. This was not required earlier it was introduced sometime in 2019 or so.
https://developers.google.com/maps/documentation/javascript/get-api-key
See attached on how to apply the API KEY.
Anthony
Message 133 of 134
(993 Views)
سلام اقای گروسی امکانش هست فایل این پروژه رو برام ایمیل کنید یا اینکه راهنمایی کنید
من دانشجوهستم و دقیقا این پروژه رو برداشتم
ممنون میشم کمکم کنید
alireza.zare055@gmail.com
Message 134 of 134
(526 Views)
