i would like to open labview just like i open my microsoft word by typing msword in run command
Hi all
I would like to open the labview by typing a command in the Run
For example we type mspaint to open the Microsoft paint in the Run (start--->Run--->command)
i would like to know the command
Message 1 of 8
(3,460 Views)
If you add your Labview installation directory to the "Path" Environment variable of your computer, it should work.  Windows just looks in all those locations when you just type the program's filename.
Message 2 of 8
(3,457 Views)
Maybe you'd be interested in testing Colibri, it's an application launcher, quite handy if you have different version of LabVIEW installed.
  1. Strike the "hot key"
  2. Type the first letter of the name of the app you want to launch
  3. Press "Enter"
  4. There you are...
To launch the version you want, you can type "71" to launch LV 7.1.1 or "82" to launch LV 8.20. I couldn't imagine a day without using this soft even if it's not as good as QuickSilver for Mac...
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
Message 3 of 8
(3,452 Views)
I had used a similar program in the past, but found it used too much in terms of memory usage and CPU usage. Colibri looks pretty good. There's a bunch of these programs available.
Message 4 of 8
(3,428 Views)
I will be thankful if you can explain the procedure in detail
Message 5 of 8
(3,404 Views)
Hi Narendra,
To change the PATH environment variable:
    1. Right-click on My Computer, and then click Properties.
    2. Click the Advanced tab.
    3. Click Environment variables.
    4. Click on the PATH variable within the Systems Variables list.
    5. Click Edit.
    6. Append the search paths for the applications you would like to launch.  Paths must be separated by semicolons.  (For LabVIEW 8.20, the default path would be: C:\Program Files\National Instruments\LabVIEW 8.2)
    7. Click OK three times to close all of the dialog boxes.
You must be an administrator to modify a system environment variable. System environment variables are defined by Windows and apply to all computer users. Changes to the system environment are written to the registry, and usually require a restart to become effective.
Thanks to Microsoft.com for providing most of this information here.
Cheers,
Spex
To the pessimist, the glass is half empty; to the optimist, the glass is half full; to the engineer, the glass is twice as big as it needs to be has a 2x safety factor...
Message 6 of 8
(3,356 Views)
Great move spex ! it works fine for me 🙂 🙂 🙂
Epictetus
Antoine Chalons
Message 7 of 8
(3,340 Views)
Smiley Very Happy
it worked very well
thank you
Message 8 of 8
(3,314 Views)
