i would like to plot my data, being read from a daq board.
The data should not move off the graph, as i would like to be able to see the whole graph from start, to current. The x-axis would be 24 points, indicating each hour of the day, and the y-axis would be from 0 to 40.
what type of graph do i use and howdo i go about it. I've tried profudely, but can only get part of it right. A demo if possible will be greatly appreciated.
(2,534 Views)
First, get formatting of the x axis. Put it on relative time and precision 0. Next, from the palette, set both x and y autoscaling off (two buttons with a blocking control). Then, put the last value of x as 23:59:59 and in the y axis the last value should be 40. Now if you wire data to it, it won't autoscale, and you'll see data going on.
Hope this helps
(2,534 Views)
This should be a XY graph and you must wire seconds (0 to 24*60*60) in the x axis
(2,534 Views)
