i2c debugging help needed with an oscillascope
I am trying to debug my i2c slave device and was hoping that someone could explain how to use an oscillascope to debug it and how to set up the vi to use the oscillacope to test my scl and sda values.
rbme
(3,069 Views)
What does this have to do with LabVIEW? It sounds like you need to know how to use a scope. Do you know how to set up triggers? Do you know how to set up a timebase?
EDIT: Seems to be related to this, and should probably go into that thread instead of a separate one.
Message Edited by smercurio_fc on 08-12-2008 10:49 AM
(3,045 Views)
Hi rbme,
Depending on the oscilloscope you are using to debug your i2c device, there might be an instrument driver located at ni.com/idnet. The instrument driver will allow you to control the oscilloscope with a set of software routines reducing software development time.
Andy L.
(3,026 Views)
