i2c labview Implementation
Well, your spreadsheet shows that you are not sending the hex value 19 and a carriage return with the LabVIEW code. Without actually seeing your LabVIEW code I don't know what you expect us to be able to do.
Message 11 of 15
(1,824 Views)
Hi All,
this is the vi that I am using.
Any suggestions are welcome. Thanks
Message 12 of 15
(1,803 Views)
Your code clearly indicates that you are not appending anything to the string control where you enter the command. If the instrument requires a CR/LF then you need to append these to the string before you send it to VISA Write.
P.S. When using latching Booleans and event structures place the button inside the Value Change case so that LabVIEW will reset the Boolean control.
Message 13 of 15
(1,796 Views)
Hi Everybody
I am trying to test digital pots using labview bt i can get the simulation working
any help will be thankful
thanks in advance
N.B-as the name says i am new at labview so plz any help will useful....
Message 14 of 15
(1,677 Views)
Does your question have anything to do with the message thread you posted in?
Please start a new message thread.  Post specific questions on where you are having problems.  Not this generic "I am new, I need help."  And please don't use text message abbreviations.  Use your entire keyboard to post a clear message.
Message 15 of 15
(1,675 Views)
