iC-Haus GUI software built with LabVIEW Source code
I'm searching for source code of iC-Haus GUI software that is built in LabVIEW:
https://www.ichaus.de/software
I'm developing application and source code will make much more easier to develop if i had source code. Does anyone has it or knows where to find it?
(2,917 Views)
Hi Andraz,
why don't you ask iCHaus? They should be able to help you with their own software…
(2,878 Views)
Indeed, apart from asking nicely to the original owner of the code, I don't think you will be able to get yours hands on it.
Hopefully they maintain tech support for their software and might be able to implement new feature you might need (or fix bugs if you found some).
Good luck!
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(2,870 Views)
