11-21-2007 03:36 AM
11-21-2007 04:07 AM
Bad news : there is a property node that should take care of that, and control the clockwise or counterclokwise text orientation. Unfortunately, it doesn't work neither in LV 8.2 nor in 8.5... This seem sto be a bug. The property disn't existe in 7.1.
Somebody else to confirm ?
11-22-2007 08:13 PM - edited 11-22-2007 08:14 PM
There is a very simple solution : create a free label (use the text tool) and place it over the scale label. A right click will let you choose the label orientation. That what I did on the attached front panel. Of course you'll choose the right back ground color !
11-23-2007 12:53 AM
HI
Thanks for the replies.
I can place a text label.But the problem is when the user takes a print out of the graph,the text label wont appear as its not a part of the XY graph.Any work around 4 this?I have given the reference of the graph as the control reference 4 the print option
Thanx again
11-26-2007 06:37 AM
