iTAC.MES.Suite
I'm trying to integrate LabVIEW with iTAC.MES.Suite using a .Net library in order to communicate with the MES system. The library is called Imsapi-dotNet7.11.01-2 and I'm having a hard time figuring out the session setup. Does anyone have any  experience with this API?
Thanks in advance.
Marcos.
(5,596 Views)
I don't have any experience with this .NET library, but to be clear is the problem that you are having related to calling the functions from LabVIEW, or is it something specific about the use of the functions in there.
If the problem is with the use of the functions then it would be a good idea to  see if the developer of that library has documentation available for it.
(5,533 Views)
Hi Richard, thanks for your reply.
The problem is related with the use of the library, I'll wait for the developer support then.
(5,521 Views)
Hey,
I am in a similar situation.
Could you please suggest if you found a way to fix this issue dll issue?
TIA
(656 Views)
Hello, Its been a while since this project and my company developed a working library to handle this. Are you interested in a license?
(633 Views)
