iak File in Executable LV 8.5.1
I am building an application using LV8.5.1 which uses Fieldpoint (serial).
The code calls in an iak that is located in a specific location on disk. Is there a way of getting the installer to create the iak file in the correct folder so that the code calls it correctly?
Thanks in advance
ssk
(2,858 Views)
Have you tried doing a search on the topic "Fieldpoint iak"?
For instance, have a look at this thread.
(2,844 Views)
I did read this post prior to posting but discounted it because it was for cFP. Reading on, it is applicable to all systems!
(2,827 Views)
