iamaqdx sequence
How can i use the Imaqdxseuquences VI, it requires an input array of images which control should be used to get array of images. Any suggesstion.
(2,560 Views)
You have an example for this function.
C:\Program Files\National Instruments\LabVIEW 2010\examples\IMAQ\IMAQdx Examples.llb\Low-Level Sequence.vi
Or from the Example finder: Hardware I/O->IMAQdx->Low Level-> Low-Level Sequence
Hope this helps.
And for question regarding vision, post in the Machine Vision board.
Regards
(2,555 Views)
