icon couldn't be found
I couldn't find this icon:)
(3,061 Views)
It is not an icon, but a "property node". Get it from the palette and wire a reference to a waveform chart to it. See how far you get.
(3,033 Views)
Another wat to get to the property node go to the block diagram and press Ctrl+Space and type in "Property Node". The link has more information on how to use them.
http://zone.ni.com/reference/en-XX/help/371361E-01/glang/property_node/
Tim O
(2,991 Views)
If you found this object on a snippet, is it likely that it got inserted by the snippet mechanism and the actual code could be much simpler. Where did you find this graphics?
(2,986 Views)
You can find from the link given below. But I am not sure wether is working or not
http://forums.ni.com/t5/LabVIEW/tempeature-stability/m-p/1737002#M609228
(2,958 Views)
Well, it is either working or it is not working, there is no grey zone. It should be easy to tell when running the VI.
(2,948 Views)
Yes, I see your point. I am going to insert this part to my vi, then see what is happening. I have some wuestions but I will wait till it works.
thanks for interests.
Best.
(2,920 Views)
