icon editor sneaks to 2nd monitor
A WindowsXP setup with primary monitor as portrait and secondary as landscape orientation.
But in LabVIEW 2009 the icon editor always appears on the 2nd screen.  Most of the
time my 2nd monitor is off but thankfully I turned the 2nd on just to discover this behavior.
Is there an ini file setting to make the icon editor always appear on the primary screen?
Thanks in advance
(3,024 Views)
Accepted by topic author Odd_Modem
Hi odd_modem,
have you looked into this group? Here you find updates, which also should solve your problem...
(3,005 Views)
Hi Odd_Modem,
I hope the Icon Editor is working properly now. Please mark GerdW's post as the solution. I've followed the link and verified that it fixes the issue.
Imtiaz Chowdhury
Project Manager
Green Running / Austin Consultants
(2,920 Views)
