idea for grouping in 1D numeric series
Hi, I need to know your idea in my numeric series.
For example, consider a series, "1:0.0000011 2:0.0000011 3:0.0000148 4:0.0000022 5:0.0000159 6:0.0000002 7:0.0000148 8:0.0000022 9:0.0000159 10:0.0000002....."
The regular group is just started in index #3 with size of 4 and contained two irregular parts.
My problem is the series can be varied according to my parameters.
Sometime, no irregular part or size of 2....
My question is how to detect "generally" the regular group in a 1D matrix?
Is there some useful technique for this work?
labmaster.
Message Edited by labmaster on 07-28-2009 11:15 AM
Message 1 of 12
(4,660 Views)
Define:
  • "regular group"
  • "size of 4"
  • "irregular parts"
  • "varied according to my parameters" - varied how, and what parameters?
Message 2 of 12
(4,645 Views)
Sorry for my expression.
I meant the series was created from my private parameters.
Therefore, you don't have to take care about it.
Just think about 1D series contain regular group and irregular part.
The irregular part is started from index #1 all the times.
I have to know you the size of group could be varied in some situations.
labmaster.
Message Edited by labmaster on 07-28-2009 12:07 PM
Message 3 of 12
(4,634 Views)
I read then re-read then
Please slow down and gothrough a couple of your examples and show us which part is which.
Ben
Message 4 of 12
(4,624 Views)
The length is irrelevant. Use the match regular expression function.
Is this what you wanted to do?
Cory K
Message 5 of 12
(4,619 Views)
It also works the same way if the 1st part of the expression is what is varied.
Cory K
Message 6 of 12
(4,615 Views)
Let's consider one more example: "numeric series"
1, 2, 3, 4, 5, 3, 4, 5, 3, 4, 5, 3, 4, 5,...., 3, 4, 5, ....
(My real series is expressed in double precision number)
Each number have a proper index in this series.
The irregular part: "1, 2"
The minimum regular group part: "3, 4, 5"
The starting index of regular part: 3 (when the first is 1)
Do you understand my question?
It is related to grouping.
labmaster.
Message Edited by labmaster on 07-28-2009 12:51 PM
Message Edited by labmaster on 07-28-2009 12:53 PM
Message 7 of 12
(4,606 Views)
That is confusing. If you have an array of those values, then the index of the first occurence of '1' is 0 and the index of the first '3' is 2. The question still remains, what exactly do you want to do with this series of numbers?
Message 8 of 12
(4,600 Views)
I did.
A big index was selected. then find it again -> size of group.
labmaster.
Message 9 of 12
(4,574 Views)
Dennis, nice to meet you.
just for explanation with start index = 1.
labmaster.
Message 10 of 12
(4,572 Views)
