idle state for DAQ.mx
I am tring to get a specific data output from my DAQ.mx, but when my data is over i need it to stay in high voltage. How can i do it?
thank you.
Adi
(3,572 Views)
Hi Adi,
you probably talk about digital outputs: when you want them at HIGH level you need to set them to HIGH…
(3,567 Views)
actually i'm talking about analog output, i attached a photo.
when my waveform ends, i need the output to be on voltage that i define (not 0).
i know there is a function of idle state for miHSdio that called - configure idle state.
thanks for your quick respond.
(3,554 Views)
Accepted by topic author Adi_Mik
Hi Adi,
What happens when you define the last sample to have your HIGH level value?
HSDIO is totally unrelated to analog outputs…
Which kind of hardware do you use? What does the manual/specs tell about the feature you try to implement/use?
(3,550 Views)
You were right, I set the last sample to the high level and it works.
(by the way, I'm using NI PXIe-6363)
thank you very much!
(3,532 Views)
