if i load 1GB file in labview array, it shows memory full. How tom handle it?
(3,160 Views)
Who is tom?  Is that the person writing the program?  Show us the code that is giving you trouble, along with the error message.  For example, you mention a 1GB file, but a file of what?  Is it a Text file?  Are you reading characters, or are you reading numbers?  What function(s) are you using to read the file?  What is the precise Error Message?  Where is the code?
BS
(3,156 Views)
Don't read it all at once.  Just read the parts you need when you need it.
(3,154 Views)
Please take a look at this NI KB here.
Kudos are the best way to say thanks 🙂
(3,148 Views)
Is it a binary file or a formatted file?
How are you reading it?
Once you read it, what is the program doing to the data (e.g. graph it all at once, process it, etc.).
Do you have LabVIEW 32bit or 64 bit?
What is your OS?
(3,123 Views)
