if input is one constant from a range, is there a tool that can make output select for that number
I'm not really sure if this has a name, but I want to input a constant between 0 and 7. I would like there to be 8 outputs, and depending on the value of the input, the corresponding output is selected. The output could be 1,0 or T/F. I think I could achieve the same goal with a lot of programming, but I wondered if this was already a tool.  Thanks.
Message 1 of 8
(3,518 Views)
Put the eight values in an array and use the "input" to index the array for the output.
Unless I completely misunderstood your intention...
Message 2 of 8
(3,517 Views)
case statement? the cases can be setup to be your inputs, they don't have to be specifically 0-7, case can contain anything to output. Of course, if you want 0,1 in some cases and T,F in other it gets a bit more complicated, but that could be handled in a number of way.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
Message 3 of 8
(3,513 Views)
I have made a quick sketch of what I need. Im not sure if this is what you were describing.  Thanks
https://docs.google.com/drawings/d/1ytM01yggd1WrcJT1ygPw_iouDmsntCCKYltCnb2YSSY/edit?usp=sharing
Message 4 of 8
(3,509 Views)
Can you just attach your drawing to a message.  I can't get into Google Docs.
Message 5 of 8
(3,491 Views)
Accepted by topic author Adamramm23
Index Array will do what you want.  Just have all of your possible outputs in an array and index out whichever element you want.
Message 7 of 8
(3,483 Views)
Or are you looking for something like this?
Message 8 of 8
(3,479 Views)
