illegal mode 0x72 in GenEA
If something helps, i have the same trouble and what generates this error for me is, to show or activate the "timeout" on shared variables (read or write at program). Trying to use it gets that error. I can´t figure out why this happens.
Salutes
Message 11 of 14
(968 Views)
Accepted by mniedernhuber
I also have pointed out that the timout on shared variables is the problem.
You are not allowed to let the timout terminal of the shared variable unwired. It says that unwired is 0ms but this brings the system to show the 0x72 GenEA error.
I just wired a 0 constant to the variable and it worked.(reproducable)
Cheers
Nottile
Gernot Hanel
IONICON Analytik Gesellschaft m.b.H.
Message 12 of 14
(948 Views)
Hi nottilie,
you are the HERO!!!! Great! That was the solution. Smiley Very Happy
I have just changed all shared variable timeouts and wired a constant with zero. It was possible
to load and execute my largest project in LV2012 without that error message.
Thanks and Kudos to You
Stefan
Message 13 of 14
(943 Views)
Hi guys,
hey Stefan,
thank you for your discussion.
I will forward this to our development team.
Abduelkerim
Sales
NI Germany
Message 14 of 14
(934 Views)
