image as a background for XY graph
Is there a way to have an image imported as backgroud for an XY graph? I
want to plot the tragectory of something moving on that image and update it
in real time.
Ioan Tudosa
(3,335 Views)
jus some clue for you...
ian.f.k
labview@ianfung.net
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
(3,335 Views)
Here's another example. Basically you need to make the graph area transparent and overlay it on the image media (intensity plot, picture control, etc.)
(3,335 Views)
> in real time.
You can do this, but the most direct approach doesn't work due to
optimizations in the graph. The direct approach would be to take the
graph into the Customize mode and replace the normally black rectangle
with your image. The problem is that the graph cheats a bit and will
erase the plot using the background color of the plot area rectangle,
meaning that it will still erase over your picture with a rectangle.
The solution is to make the plot area transparent and place the image
behind the plot area. You might even want to place the picture behind
the graph and make the graph
frame transparent too. If this placement
is done inside the control editor, the image is automatically a part of
the graph control. If done on a regular panel, you might want to group
the graph and picture together.
Greg McKaskle
(3,335 Views)
Thank you, it works.
Ioan Tudosa
"Greg McKaskle" wrote in message
news:3EB09E06.4020502@austin.rr.com...
it
> > in real time.
> The solution is to
> the graph and make the graph frame transparent too. If this placement
> Greg McKaskle
(3,335 Views)
