image byte order
Hi, again,
its happened, because in the absense of signal the background noise of your camera distributed (may be "stretched" right word) over whole histogram.
You should use interval range input (which should be set to min/max possible values delivered from your camera).
See the code below:
and see that histogram on the left side contained "delta" peaks, and histogram on the right side — not.
Andrey.
Message Edited by Andrey Dmitriev on 02-12-2009 12:46 PM
Message 11 of 12
(641 Views)
Thanks, Andrey.
Message 12 of 12
(622 Views)
