image capturing black screen
I connected a usb to labview using the IMAQdx. At first, it would run but would produce timeout errors after 5 pictures. Now, I manage to get the cycle to run 50 times but the image only comes out as a black screen. What could be the cause of this and how can I fix this?
(4,192 Views)
I would like to take a look at your VI. Attach it as a file or take a screenshot and post it.
If you want people to help you, you have to situate your problem better then that.
Regards
Ruts
(4,170 Views)
Thank you for your reply. Attached are two attempts that both produce the timeout error
(4,134 Views)
Can you see the camera in NI MAX?
(4,118 Views)
Accepted by topic author F.N
I think his problem is solved in this post:
http://forums.ni.com/t5/LabVIEW/imaqdx-timeout/m-p/2823844#M826279
Guess that there is no problem with the connectivity of his camera. I'd like to ask you to mark it as solved if your problem is solved F.N.
(4,096 Views)
