image on tabpage caption?
as we can add images in the tabpage caption in vb.net.. or visual basic using image list property ... is it possible to add that kind of image in labview.. ???
(7,621 Views)
Right-Click the tab, select Advanced > Tab Layout.  You will find the options for using images or text with images.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(7,610 Views)
Excellent question and answer!
I did not know you could do that.
Thank you,
Ben
Message Edited by Ben on 04-24-2006 08:53 AM
(7,602 Views)
Hi Darren
nice extension to your icon nugget
greetings from the Netherlands
(7,567 Views)
thanks,,,,  Smiley Happy
(7,541 Views)
Hi
Found the Option and turned it on but i cant seem to figure out how to get an Image in there?  Any Ideas?
Nice tip btw 😉
Edit: The "Import Image from clipboard is greyed out " so either it is not available or more than likely i need to put the image on the clipboard!
Edit No2: OK i needed to put an image on the clipboard, which i didnt realise was just a copy from MS Paint or wherever.  I need a Holiday!
Craig
Message Edited by craigc on 10-05-2007 04:29 AM
Message Edited by craigc on 10-05-2007 04:31 AM
LabVIEW 2012
(7,041 Views)
