image processing
Hello i am trying to do the edge detection without the function IMAQ Edge Detection am asking if its possible just by the fonction IMAQ convolute please help
Message 1 of 12
(4,034 Views)
Yes, but it won't be as good as a Canny edge detector: https://en.wikipedia.org/wiki/Canny_edge_detector
See: https://en.wikipedia.org/wiki/Kernel_(image_processing)#Edge_Handling
You'll need a [-1,-1,-1 ],[-1,8,-1 ],[-1,-1,-1 ] convolution matrix.
More generally: https://en.wikipedia.org/wiki/Edge_detection
Message 2 of 12
(3,982 Views)
I think there's a Canny detector hidden somewhere in LabVIEW Vision (at least I recall seeing mention of it in the Forums) ...
Bob Schor
Message 3 of 12
(3,968 Views)
Bob, could be another homework assignment?
Not sure why you'd want to do this without the functions that are made to do it...
Message 4 of 12
(3,955 Views)
hello
i need the block diagram of the IMAQ Edgedetection.
Message 5 of 12
(3,936 Views)
Hi khamed,
why do you need that when you should implement an algorithm without that function?
There are two options:
  1. You can look inside that IMAQ function by opening it's block diagram
  2. You cannot look inside this IMAQ function because the block diagram is protected/not available.
As I don't have IMAQ installed you need to check those 2 options on your own. Either NI allows you to look at the block diagram - or nobody (outside NI development team) is able to look at…
Why do you create all your threads with the same non-descriptive title?
Message 6 of 12
(3,926 Views)
@khahmed77 wrote:
hello
If it's not open, that's not possible (not allowed anyway).
It probably won't do you much good, it's almost certainly just a call to a dll function.
Message 7 of 12
(3,921 Views)
It certainly is. Back in LabVIEW 5.x days some of the Vision functions were implemented in LabVIEW G code such as the barcode decoding. They soon changed it to functions in the Vision DLL and and the VI was just a simple Call Library Node on the diagram.
The original G implementation wasn't exactly what I would call clean but they did work sort of and I even did some improvements on them for a project back then. But one big driving factor for NI to implement everything in the Vision DLL was also the fact that they used the Vision Toolkit core in LabWindows/CVI too. That move saved them having to maintain two different code implementations in parallel.
Nowadays just about every single vision function in the Vision Toolkit is really just a Call Library call into the vision DLL.
Rolf Kalbermatter  My Blog
Message 8 of 12
(3,915 Views)
@rolfk wrote:
It certainly is.
Yep.  Here is the Block Diagram of IMAQ EdgeDetection (LabVIEW 2018):IMAQ EdgeDetectionIMAQ EdgeDetection
Bob Schor
Message 9 of 12
(3,907 Views)
obviously i didn't ask for that.
Message 10 of 12
(3,903 Views)
