image subtraction original image destroyed
Hello all,
Sorry if this is a repost of a question previously asked. I can't seem to find it in the forum.
Basically, I have a background subtraction vi that takes a bg image and subtracts it from a realtime (RT) snapshot image. The problem is, I can only display the subtracted image and not the snapshot. I've tried converting the RT image to an array and recover it with a new image name, copy it to a new blank image under a different name, but nothing seems to work.
However, strangely enough, if I don't attempt to branch the RT image to a display in the front panel and probe before and after the subtraction routine, they appear fine!?!?
Any help would be greatly appreciated. I've attached my vi's in a zip file. MAIN.vi is the main program to run.
I believe you will need the NIVISION ACQUISITION package to view it properly.
Anderson Chen
(3,338 Views)
No one has any ideas?
No quick fixes?
(3,313 Views)
Anderson,
First, the overlaycapture.vi where the actualy acquisition is missing from your zip file.  It appears that there might be a misunderstanding of how the image datatype works. The image datatype is actually a pointer to a memory buffer where the image data exists.  That means, that previous image data is not maintained in the program unless it is copied over to a new location.  Chances are that you are missing this background portion because you are subtracting it out!
I hope that helps!
Jeffrey Phillips
National Instruments Applications Engineer
(3,297 Views)
Thanks for your reply.
Hum... I guess I zipped the wrong files. Let me try it again.
So I'm still addressing the same memory if I use the IMAQ copy command to copy it to another "image" created using the IMAQ create command?
Anderson
(3,293 Views)
One small correction in the main.vi.
Got the wiring mixed up between IMG SRC and IMG DST.
(3,292 Views)
Thanks Jeff.
I think I finally understood you. I've fixed the issue.
Anderson
(3,286 Views)
