03-21-2013 03:51 AM
Hello GerdW,
In that VI you posted, How to edit the Cluster that gives input to Property node. How to add colour and Digits in that cluster input ?
Regards
Neo
03-21-2013 03:59 AM
Hi Neo,
are you talking about the "Z scale" values? That's an array of cluster and each cluster contains a number and a color (as described in the context help of that property node!).
To edit those values you simply click them with the edit tool (as usual when editing block diagram constants)...
03-21-2013 05:19 AM
Hello GerdW,
Thank you very much for your quick reply. I have one more question.
From the block diagram data flow , it seems like you have Image data at first and then picture is drawn. How did you get the image data first ?? where did you extract this data ?
Regards
Neo.
03-21-2013 07:06 AM - edited 03-21-2013 07:06 AM
03-21-2013 07:14 AM
Hi GerdW,
Ahhhh... k. Got it. Iam just lost after going through all the posts .
THANK YOU
Regards
Neo.
09-09-2019 12:39 AM
Can you share the example, like how can we do the same using vision library ?
