image transfer from one pc to another through usb in labview 2013
       Actually i want to transfer number of images through usb from one pc to another for that i have tried many options but its not working..i am attaching both the sending and recieving VI,,
please do look into it and send your solutions..i would appreciate your help..Thank you 🙂
(2,725 Views)
Hi
Only a proportion of forum members will be running LV 2013. If you can post the two VIs for an earlier version it might help.
Use File > Save for Previous Version... and select LV 2012 or earlier.
(2,693 Views)
Thanx a lot for your response m attaching the older  version...please do go through it thankyou..
(2,682 Views)
Hi bizashZ
Are you sure you mean USB ?
You appear to be using the COM1 serial port in which case you should just use an RS232 crossover (null modem) cable to connect your 2 PCs.
(2,677 Views)
ya u r right ! i meant com1 only !! thank you
(2,670 Views)
