imaq.dll error when boot up Windows
I have a little Problem with Labview 8.6. After i installed the driverpack for the dvd, my Windows give my the error
Der Prozedureinsprungpunkt "ProgramFPGAs" wurde in DLL "IMAQ.dll" nicht gefunden.
my tranzlation
the entry point "ProgramFPGAs" is not found in the Dll " Imaq.dll
Labview start an run without problems, only this message at windows boot up is annoying.
was anyone a idea to fix the problem or atleast stop that messagebox
Thank you
(3,137 Views)
Accepted by topic author DRhatje
Hi DRhatje.
Good Morning and I hope your well today. Thanks for your post.
I think thats a pretty good translation,  the error message I was thinking of can be found in the knowledgebase article below.
The suggested cause of the error is that the IMAQ.exe is set (by default) to start on startup. But if you don't have a framer grabber installed on the machine then you could well see this error. The solution is to remove the exe from the startup list on your system. The steps to do this is listed in the link below but in summary,
From the section in the screenshot you sent me you should be able to select the "Selective Startup", then navigate to the "Startup" tab and uncheck the IMAQBoot.exe.
If this reverts back to the default settings on restart, this is probably an indicator that your Admin Rights on this PC are limited.
I think that a quick way to check this is to go to Start>Run and type "regedit". This is essentially a more advanced way to manipulate similar settings, but if you don't have Admin Rights on the PC then you would most probably be denied access. In any case though, please ask one of your IT colleagues to use their passwords and change this setting. It will get rid of the warning you are seeing until you start using our Vision Hardware and need to reactivate it.
Make sure you click on "Apply" before you exit this utility.
Why do I get "IMAQBoot.exe - Entry Point Not Found" error when I restart computer?
http://digital.ni.com/public.nsf/allkb/AD70B1036D5B950B8625752400578CFE?OpenDocument
This should at least remove the error message upon start up.
Please let me know how you get on and I hope this helps!
Kind Regards
James Hillman
Applications Engineer 2008 to 2009 National Instruments UK & Ireland
Loughborough University UK - 2006 to 2011
Remember Kudos those who help! 😉
(3,129 Views)
Thank you very much.
(3,114 Views)
Hi there,
Thanks for the reply and I am glad the information found you well.
Once again, thanks again for using the NI Discussion Forum and I wish you all the best with your application(s).
Note: Also thanks for using the new forum features - namely the  Accepted Solution Tag.
Kind Regards
James Hillman
(3,107 Views)
